New here!
Just bought a 1994 Honda Accord Ex 2.2 vtec.
Already somethings are going wrong with it.....a/c fuse blowing when hitting the a/c button. Shifting hard into Reverse. Want to fix these but not sure where to start with the fuse blowing. |
Post To Correct Forums For Fixing Things
Hi and Welcome to you..:) I moved you to this one :)
Do you have a manual and a volt meter?
I'd start with testing the ac clutch coil for porper resistance...there is also a recall on some of these where the wires to the ac compr can get worn and cause a short as well..... Shifting hard.....start with inspecting the mounts. Also since you just got it, unless you can confirm, I'd do a drain and fill of the trans with Honda fluid. |
