new rear strut assemblies
Recently I changed out the old struts/springs on the front end of my 92 Accord. Both coil of the front springs were broken on this vehicle with 215,000 miles on it. I got those Monroe "Quick Strut" assemblies. Am considering doing the same for the rear. I don't think the rears are broken or anything, but just old. Do the rear struts/springs wear and need to be replaced similar to the front, or do they generally last longer and don't exhibit wear problems more or less evenly as compared with the front? Is it not a good idea to just replace the front and leave the rears alone if they "seem" okay? Any comments appreciated.
I'm still on OEM struts on my 94EX at 240+K miles and IMO they are still working fine. Judging strut performance is akin to water witching, as you will get plenty of opinion, but not much fact.
good luck |
(Post 331094)
You've got the new fronts to compare the rear to.
Just do the generally-accepted test of pushing down hard on the rear corner and see if there is only one rebound. If the rears behave as the fronts do, lucky you! |
Originally Posted by Tony1M
(Post 331175)
Also, is it not typical to find that the rear control arms need replacing along with the rear struts? |
Originally Posted by sgull
(Post 331176)
That test sounds way too easy. There must be a much more complicated and involved and confusing method/process I need to undertake.
Originally Posted by Roader
(Post 331177)
And some big, many-syllable words thrown in the test procedure too. Make it sound real official-like.
Well, when you push down on the bumper, you're applying a forcing-function. By watching how it bounces, you're evaluating the system's response to that forcing function. Big enough words?
Special tools? How about trying your best to apply the forcing-function in a way that's centered on the bumper. That means your eyes & your brain; both pretty amazing special equipment. ;) Overdamped = takes too long to return to it's final position after you let go. Underdamped = it bounces up & down before settling. Critically damped = quickly returns to it's final position without bouncing. You want it critically damped or just a tiny bit underdamped. It's pretty common for the car to rise after you let go, overshoot a tiny bit, then settle without repeatedly bouncing. You want to see whether the response is symmetric side-to-side. If it isn't, the car will have a bit of sideways action while it bounces. That would tell you whether your rear shocks are matched. Usually they get soft so gradually that it's hard to notice. But if one side gets progressively softer than the other, it starts bouncing sideways a bit. |
I knew it! Big words involved, special tools, and a much more complicated and involved and confusing method/process I need to undertake! :eek:
Seriously though, thanks JimBlake for the helpful explanation of how I should be able to do a fairly reliable evaluation. Will do! |
Having changed them myself on a 94, a 95 and 97 I can tell you this from experience. First, the old step on the bumper test doesn't work very well on these newer, lighter cars with short strut travel. That is really old school on big Chevy's etc. You will get a ride height change back to normal, especially on the rear with the quick struts. 1 to 2 inches. Springs do wear out over time, and break as you found out. If you go with the quick struts, you still will not be able to tell if old cartridges are worn out, because you cannot compress them by hand while they are mounted inside the coil spring. When I did my first one, I compressed the old spring and removed the cartridge just to see. I could easily compress it with my hands ( well not so easily, but easy enough to know they were well worn out) No special tools needed. A long pry bar will be helpful as well as a floor jack.
