no dash panel lights.
Hi,
I have a 1999 accord v6 sedan and I just installed a new stereo, after which none of the lights for my dash, guages, or rear tail lights come on. I checked the fuses and everything seems to be in order. I even tried plugging the old radio in and still all the lights didnt work. Anyone have any suggestions or ideas? thank you anton |
RE: no dash panel lights.
Did you pull on anything too hard when you were doing the install?
Not that i remember of the top of my head, but anything is possible.
Did you disconnect the battery when you installed the radio. You might have blown a fuse.
I have checked all the fuses, they are fine.
I believe there is an under-hood fuse box for that car as well.... did you check those? I seem to recall there being a fuse under the hood that pertains to both the tail lights and the dash.... If you have checked all of those as well then it's time to find a wiring diagram.
ORIGINAL: anton17 I have checked all the fuses, they are fine. |
| All times are GMT -5. The time now is 04:13 AM. |
