No parking lights and dash lights?
Dont know what to do i checked all the fuses under the hood and on the drivers side they are all good but cant find the problem ..
my parking lights dont work and my dash lights and plate lights. I have a 1996 honda accord ex anybody know what it could be? ... Thanks marky4 |
RE: No parking lights and dash lights?
did you chk fuse # 32 underhood fuse box ???
if fuse is ok you might have a bad combo switch , if the fuse is ok, you need to chk if you are getting power at the red/green wire at the combo switch it should be hot all the time .. if you get power there, turn the parking lites on and chk to see if you get power at the red/black wire.......if not , give power to the red/black and see if the dash lites and parking lites turn on,, if they do you got a bad combo switch if yopu power the red/black and lites still do not turn on,, then most likely there could be an open in the red/black wire .. try what i suggest and let us know , before we go any further |
Man you are smart thanks it was the combo switch you know your hondas:).....:D
glad you got it handled ..:)
