-   -   no spark (https://www.hondaaccordforum.com/forum/general-tech-help-7/no-spark-33991/)
tritonfaststrike Aug 4, 2010 07:18 AM
no spark
ok guys i need help my wifes 1996 accord 2.2 5 speed just died leaving stop light yesterday ..i tried to start it .acted like it wanted to fire but just wouldnt light .so i had her push start me .Wow that was a sight .anyway it started .but i couldnt give it any gas .made it about 1/4 mile died check engine light came on .got it home pulled sprk plug wires oil on all 4 so valve cover need resealed .fuel pump runs .got no spark to the plugs .coils got fire .when i crank the motor my rotor in dist is turning so i dont think its timing belt .i got fuel got fire at the coil but no spark at the plugs .any suggestions thanks in advance .i was thinking igniter
deserthonda Aug 4, 2010 10:21 AM
could be the igniter,,,,there are write ups on the DIY section on how to test it ,,,,,,but if it is bad, car will not start even when push started
http://www.techautorepairs.com/ignition.html
also......read the code and post it here..
tritonfaststrike Aug 4, 2010 07:18 PM
thanks for the response desert honda .quick question .did the paperclip jumper to check codes .i got 73 seven slow blinks and three fast ones ..after my wife push started me she ran for about 1/4 mile couldnt give it much gas it would die .then check engine light came on that was it died again .towed it home .i did the test turn on the key check engine light comes on 2 seconds then its suppose to go off .but it stays on .is this because the check engine light came on .now it will stay on till fixed .thanks again for youre time.
PAhonda Aug 4, 2010 09:39 PM
That is a misfire for cylinder number 3 (OBD2 code is P0303).
If the spark plugs have not been changed in a while, change them. Always use the NGKs that are recommended in the shop manual. Also inspect the spark plug wires, distributor cap and distributor rotor.
tritonfaststrike Aug 5, 2010 01:40 PM
ok hears an update got fire from coil got fire to the little button inside the cap from coil.but no fire from cap to spark plugs .will a disturbitor cap and rotor completely fail were fire wont get threw:confused: or is my coil to weak
PAhonda Aug 5, 2010 03:34 PM
I would replace the distributor cap and rotor if they haven't been changed in 2 years or 40K miles. They can wear out over time.
tritonfaststrike Aug 5, 2010 04:41 PM
thanks pahonda
tritonfaststrike Aug 6, 2010 08:49 AM
Update
CHANGED CAP ROTOR WIRES .she fired right up it appears my rotor had small hole .it was firing threw to my dist shaft . thanks deserthonda .and pahonda .keep up the good work:)
