No Tail Lights!
95 accord wagon lx
Blinkers work Brake lights work Lights work in reverse Left blinker makes an ehhhhhhhehhhhehhhhhh sound on occasion. Have to turn blinker on and of to make it stop. Changed light relay Changed cluster Changed rear lighting wiring with the working ones from my 96 wagon. Nothing. Any thoughts would be GREATLY appreciated. |
did you chk fuse # 32 ,15 a, under hood fuse box??? the same fuse is also for dash lights,parking lights, license plate lights so if those work then fuse is ok
if fuse is ok, turn lights on and chk for power at the Black/red wire at the sockets ,if fuse ok and no power back there it could be a bad combo switch . |
Thank you! That exactly what is was. Labeled small lights cant believe i didnt check it from the get go.
| All times are GMT -5. The time now is 09:23 AM. |
