oil leak
I noticed a little oil consumption from the last time I changed my oil. 99 LX 4 drSOHC V-TECH 120000 miles.I run synthetic so I go about 5000 to 6000 miles between drains, its also all hwy miles. Its not uncommon for me to add a quart during that time. It was more this time. So I tooka look around and saw oil under the distibuter and in that general area. Not real wet.The valve cover gasket was new at 105000 miles. any thoughts.
RE: oil leak
Change distributor Oring, PCV Valve and its grommet and hose, should be good to go but that seems like a lot of consumption / leakage for a small seep you are refering to.
| All times are GMT -5. The time now is 03:14 AM. |
