Oil Leak
I have a 2004 Accord 6 speed coupe... I am getting an oil drip that appears to be coming from around the clutch inspection cover, I believe. I have not yet received my factory shop manuals to look for a scource, so any ideas? Is this a common problem?
Thanks in advance! [align=left] [/align] |
RE: Oil Leak
by clutch inspection cover are you referring to the opening between the tranny and engine that is used for setting the timing?
can you get us a picture? No common oil leak areas that I know of on 04's... |
RE: Oil Leak
Let me rephrase, No common areas aside from the normal ones like Valve cover etc....
RE: Oil Leak
Sorry, I should have included the picture. Hope this explains things better! Also my first picture post here.
[align=left] [/align] [IMG]local://upfiles/14210/7BA5D9A1529446DD993FE8E65052A884.jpg[/IMG] [IMG]local://upfiles/14210/E375F49D85C24A0C9241E8E73623AFC3.jpg[/IMG] |
RE: Oil Leak
Kinda looks like it's running down the engine from somewhere up top but I could be wrong.... if it is from that area and it's coming from inside I'd venture to guess that it's a rear main seal.... However, I sincerly hope I'm wrong.... Give it a bit and see if someone else has an opinion....
RE: Oil Leak
[align=left]
Yeah, my thought also... I looked around as much as I could, but did not seem to find any from up top. I will look again in the morning. I just hate to think a rear main seal with only 50k miles... [/align] |
| All times are GMT -5. The time now is 12:54 AM. |
