Oil Leak under Pressure
I have a 2000 accord ex 190K and i have replaced the egr valve, valve cover gasket, thermostat and changed the oil. I noticed the other day that I have an oil leak only when the engine is on. No other time oil is leaking.
From what I can tell it looks as if it is leaking from the center of the car. No oil leak dye has been added. What do you suggest? |
is it leaking from above the oil filter?
There is the oil pressure sensor there. |
Suggest elevating car on ramps and getting under w/ engine idling to ID leak location. Oil pressure switch is a good possibility, but oil pan, or valve cover could also be the culprit.
good luck |
