Oil Pressure / Oil Temperature / Water Temperature
Hi! There ...
I bought a aftermarket 4-in-1 Tachnometer with all senders (sensors) included I have an 1990 Honda Accord 4-Door EX, Manual Transmission However, I ran into some problems installing the sensors, or trying to tap into the right wires to get the readings .... For Water Temperature, I tried the sensors underneath the distributor cap, it gave me a reading, but the problem was...the engine won't start, only the reading comes when the tapped-connection is done after the engine is already started As for the Oil Temperature and Oil Pressure, I have no idea where those ares ... I asked my mechanic, he is unable to provide to ideas of where to install these senders We also tried tapping the sensor wire (assuming it was for Oil Pressure) on top of underneath the Oil Filter area, again, no luck Herewith, I am attaching a eBay link to the product I got, just for reference, but if you need images of the actual sensors (senders), I don't mind attaching them later on, but you can see a small image of the actual sensors on the eBay link Also, since I got this used car for $1000.00, the engine actually says F20A,not H22A ... like 2.2 it should be ... So, can someone please tell me where to tap to (the wire colours,) or the sender installation locations for Oil Temperature , Oil Pressure and Oil Temperature Thanks! The link is below: http://cgi.ebay.com/New-4-in-1-Tacho...ayphotohosting |
