-   -   Oil in Radiator (https://www.hondaaccordforum.com/forum/general-tech-help-7/oil-radiator-3433/)
calendoniahonda Jun 4, 2006 11:38 PM
Oil in Radiator
You know your having a bad day when you find oil in the radiator. I have a 98 honda accord ex with a four cylinder v-tec engine. I noticed oil on my driveway and found it leaking from the radiator over-flow. I do not see any radiator fluid in the engine, only oil in the radiator. The car runs fine, although I will not be driving it until it gets fixed. This sounds bad. Any ideas?
RTexasF Jun 5, 2006 12:00 AM
RE: Oil in Radiator
Only a guess...........cracked head or block is a possibility.
AgentofDarkness Jun 5, 2006 12:05 AM
RE: Oil in Radiator
Or a blown head gasket. Check the oil dipstick for coolant.
jrschmank Jun 5, 2006 01:05 AM
RE: Oil in Radiator
I definitely wouldnt drive it if there is antifreeze in the motor. Could do some major damage to bearings etc. I would guess a bad head gasket.
WheelBrokerAng Jun 5, 2006 01:52 AM
RE: Oil in Radiator
How about the oil coolant line going into the bottom of the radiator springing a leak?
WheelBrokerAng:eek:
AgentofDarkness Jun 5, 2006 02:56 AM
RE: Oil in Radiator
ORIGINAL: WheelBrokerAng
WheelBrokerAng:eek:
I didn't know that accords had oil coolers.
deserthonda Jun 5, 2006 04:41 AM
RE: Oil in Radiator
ORIGINAL: AgentofDarkness
WheelBrokerAng:eek:
yep they do if car has an auto tranny,,, the lower part of the radiator is the tranny oil cooler, that's why you see 2 hoses going into radiator on cars with AT..
Cale,,,,,,first of all does car have AT ?? if so you need to determine if the oil in the coolant is from engine or tranny..........car ever ovrheat ??
have a shop do a leakage test , to determing if you got engine damage..,,,,,
,if it is engine oil , it could be a blown head gasket, warped head, cracked head, on the more severe note a cracked block,,
for your sake i just hope it is AT fluid in coolant
YeuEmMaiMai Jun 5, 2006 09:42 AM
RE: Oil in Radiator
there is one sure way to find out what it is without taking then engine apart
take a sample of your coolant and a sample of your oil to have what is known as a SOS analisys done on it. If you cannot find a local shop to do it, go to your local caterpillar dealer and see if they will do it for you. I think they charge between $50 and 100 (depending upon where you are) but they will tell you without a doubt what is in your coolant and oil and then you can make an informed decision as to what to do. If your auto trans cooler cracked and you got coolant in your auto trans. kiss it good bye........
Chiovnidca Jun 5, 2006 11:57 AM
RE: Oil in Radiator
ORIGINAL: RTexasF
That would be the first thing I would test for. Seen a few cracked blocks. :(
AgentofDarkness Jun 5, 2006 03:56 PM
RE: Oil in Radiator
I thought by oil cooler he meant an engine oil cooler. Usually if i refer to the trans oil cooler i jus say trans cooler.
