OPINION: OTC 7448A Fuel Injection Cleaner Tool
Anyone have experience with the OTC 7448A Fuel Injection Cleaner tool?
This thing is purpose-built to connect directly to the fuel rail (or just at the damper with an adapter) where it bypasses the fuel system and delivers fuel injector solvent under pressure, either their propriety brew, Inject-R-Kleen, or any similar product; eg: BG FIS, Chevron Techron, etc. (BG offers a similar device: the "VIA".). The thing requires an air compressor to work. You hook-up shop air to the canister and dial-in the rail pressure for your vehicle. You then disable your fuel pump. fill the canister with solvent and hook up the delivery hose to your car's fuel rail via a quick-connect adapter. Open the valve, start the engine, and let it run until the canister is emptied (indicated by a stalled engine). Repeat with another can, or schedule another session twice a year or so. Cool huh? I'm not a fan of gas-additive fuel injector cleaners, nor am I keen on the onerous chore of removing each injector for direct cleaning. At just over a measly hundred bucks for the 7448A (plus another twenty or so for the adapter), this seems like a reasonable regular maintenance tool for the home shop. Anyone care to vouch for the OTC 7448A tool? https://i1270.photobucket.com/albums...tuff/azera.jpg |
Never heard of this.
I just use B-12 or Seafoam. Pour 1 can in the gas tank, once a year. |
Originally Posted by rockhoundrob
(Post 382843)
I just use B-12 or Seafoam. Pour 1 can in the gas tank, once a year. On my older vehicles, I might treat them to some premium once in a while. ;) |
Geez, mechanical snake oil.
Even snake oil makes your car faster - because your wallet is lighter.
I've occasionally poured Techron in the tank, but it's probably been a couple years. It can only work to the extent that things are gummed up with crud. You'd have to buy a lot of fuel from shady places before you NEED that. |
Question for those of you who've replied, and who use Seafoam, and/or other gas additive solvents:
Have you taken a gander inside your intake plenum (manifold) or scoped the inside of your cylinders, or peeked at the back of your intake valves? Granted, these aren't particularly pleasant tasks but neither are they particularly difficult. Nothing confirms efficacy like empirical observation, the opposite of "faith" of course. Anywho... BG offers the 'Vehicle Injection Apparatus', a tool that injects solvent into the intake plenum at the throttle body or the pvc port as well as through the fuel rail. The BG "VIA" seems the better tool investment than the OTC 7448A, Mityvac MV5567, et.al, Problem is, I can't source the thing.. |
Originally Posted by lothian
(Post 382852)
(Post 382852)
Anywho...
Originally Posted by shipo
(Post 382853)
Yes, I have peeked, what do those things have to do with wasting time on cleaning injectors? Answer, nothing.
Why bother screwing around cleaning the plenum? Unless there is something terribly wrong with your engine, the minor layer of varnish on the inside the plenum is irrelevant. When I use B-12 or Techron, it's because the car has been parked a while, and the fuel has lost it's vitamins. |
I had my 95 accord injectors sent off to get cleaned and balanced after >200K miles. I never used additives in my gasoline. My injectors were almost 100% expected volume on all 4 injectors and all balanced.
I took off my intake on my 95 accord around the same time. There was a slight buildup inside, but nothing that would cause performance issues IMO. |
