Outside Temperature Display
My 2003 LX Cpe has this optional dealer installed display. Actually, the display unit was in the instrument cluster and just the behind the front bumper temperature sensor needed to be installed. Doe's the 2012 LX have the ability to have this feature added?
Not as a dealer optional accessory for the 2012.
Trouble Code 1399
Hey all you Honda owners who are having trouble with your car running rough and will not idle and can't seem to figure it out. I have good news for you who have the trouble code 1399 the dealer does not want you to know what is going on to get your money. The 1399 code is not in the manual at all it turns out it is Catalylic Converter failure my son has the same problem with his prelude. If you read some of the systems like engine light flashing rough idle and stalling. save your money it is not your spark plugs or EGR valve or plug wires it is the catalyic converter is clogged and needs to be replaced. I hate the dealer takes advantage of people
