overheating?
Just parked my car. And hear it bubbling like its overheating, temp gauge is reading good.
Where do you hear it bubbling?
need mo info!!!!...is it coming from the coolant reservoir tank?is it coming from the radiator?
Originally Posted by my1st.honda93
(Post 277349)
Its coming from reservoir tank!
Once it cools, check the coolant level in the rad. Sounds like you have air in the system.
For anymore help, it would REALLY be nice to know what you are driving? |
Its a 2000 honda accord 4 cyl.
Ok, that helps.
Again, check the level in the rad, might also bleed any air out of the system. Any recent work done to the car? If the coolant is low,,,,,it went somewhere, there might be a leak. |
The rad. Is full. Just bought a week ago. It dont do it all the time just every now and then i've had it a week now only noticed it a couple times
Keep a close eye on the level of fluid in the radiator and the tank. You want to make sure that you don't have a leak.
It could be a faulty radiator cap that suddenly can't hold pressure, then allows the coolant to boil over. |
| All times are GMT -5. The time now is 08:51 AM. |
