Overvoltage 08 accord EX-L 2.4
Old Aug 18, 2019 | 02:40 PM
Apage25's Avatar
Angry Overvoltage 08 accord EX-L 2.4
Hello, Im new to the forum. I have an over voltage issue. Went to start the car and it was a weak start. turned it off and battery was dead. i put it on the charger in start mode and got it running again. voltage was at about 15.3v. i find that to be high. I took it to Oreillys for a alternator check. Alternator was charging about 13.8 she said. according to them alternator was good, 4 year old battery was bad. I had an issue with corrosion and acid around the positive post a few months ago. any with a new battery im still at idle getting about 15.2 volts. not sure whats going on. alternator is 3 years two months old installed at a dealership. figures im right out of warranty. any ideas? maybe its the voltage regulator? The power steering pump has a minor leak, perhaps that is getting in the alternator and causing a problem? sorry for the long post...I need help.
Old Aug 18, 2019 | 03:16 PM
What does your volt meter read when you measure across the battery posts when the engine isn't running?
Old Aug 18, 2019 | 03:19 PM
Apage25's Avatar
Right now battery is 13.2V with no key in the ignition.
Old Aug 18, 2019 | 06:47 PM
The battery should be 12.6V, so something is wrong with your volt meter. Check that the meter leads are not corroded where they connect to the meter. Try another meter if available.
You can also test you meter on a 9V battery or some other common batteries like AA, C, etc.
Old Aug 23, 2019 | 04:15 PM
Apage25's Avatar
My meter said a 9 volt battery was 8 volts. And it was a good battery according to the tounge test.
Old Aug 23, 2019 | 04:42 PM
Probably a good time to get a new volt meter. You can get an inexpensive one at most big-box stores.
bostongrun
Aug 6, 2012 11:04 PM
xbolloxx
Dec 21, 2011 10:19 AM
trevdogg7
Nov 24, 2008 05:48 AM
rmajors
Oct 23, 2006 09:37 PM
fireballer44
Aug 25, 2006 10:19 PM
