P0135 - 2002 Accord SE
Error Code from OBD II:
P0135 Oxygen Sensor Heater Bank 1 Sensor 1 Is this the O2 sensor that is up front visible with the hood open, or is the one from under the car? Thanks |
4-cyl engine??
Yes, it's the one in front. Unplug it & find the 2 same-color wires on the sensor side of the plug. Measure resistance between those. For a non-ULEV engine that should be 10 to 40 ohms. A bad sensor will usually be open-circuit. For a ULEV engine, the correct resistance might be different but I don't know what it should be. If that measurement is OK, then you'll have to troubleshoot wiring problems in the car. |
| All times are GMT -5. The time now is 05:58 AM. |
