-   -   P0401 egr problem (https://www.hondaaccordforum.com/forum/general-tech-help-7/p0401-egr-problem-47764/)
jjackson45 May 27, 2012 02:49 PM
P0401 egr problem
I have a 2001 honda accord v6 got the code p0401 egr insufficient flow i took the intake off and cleaned the ports i also changed the egr valve at 70 bucks after a couple of days the light came back on im fustrasted and dont know what to do can anyone offer me some help in fixing this problem thanks
crispin May 27, 2012 03:01 PM
Hello new member - thanks for joining.
Questions are to be posted in the "General Tech" area.
jjackson45 May 27, 2012 03:05 PM
P0401 egr problem
redbull-1 May 27, 2012 03:07 PM
Did you inspect and clean the EGR port in front of the injector base (lower intake manifold) of the engine? Refer to this thread:
http://honda-tech.com/showthread.php?t=2878171
jjackson45 May 27, 2012 03:15 PM
is it ok to spray the intake cleaner in this part of the motor
PAhonda May 28, 2012 12:32 AM
There is only one port on the V6. Was it filled up with carbon?
redbull-1 May 28, 2012 12:45 AM
The OP already created a separate post in the General Tech section. A lot of people only clean the intake manifold and may not have inspected and cleaned the EGR port in front of the injector base (lower intake manifold) of the engine. Refer to my post in his other thread:
https://www.hondaaccordforum.com/for...problem-47765/
poorman212 May 28, 2012 06:00 AM
Yes. Before that you might use a shop vac and a brush to get any large pieces out.
EDIT: I've merged the two threads together and tried to clean them up.
jjackson45 May 28, 2012 08:13 AM
yes it was full or carbon i think what i did when i cleaned it he first time i didnt clean it all out the intake cleaner made it like a paste and i didnt get it all out. this time i got my neighbors air compresser and blew all that trash out so i cleared the code again now ill see if it comes back on i post later thanks for all the help these forums are awesome and allows you gain knowledge and save some money
