-   -   is this a pain? (https://www.hondaaccordforum.com/forum/general-tech-help-7/pain-4663/)
dnsw24 Aug 24, 2006 10:47 PM
is this a pain?
my g/f has a 1999 accord ex 6cyl and her back brakes need to be changed i am good at working on cars i just have never worked on an accord of that year or newer. i was wondering how hard the back brakes were to change on her car i beleive they are drum brakes
JimBlake Aug 25, 2006 12:38 AM
RE: is this a pain?
I believe the EX would have disk brakes in the rear. They're pretty easy. Piston has to rotate to retract, because of the handbrake mechanism inside the caliper. Don't push it in with a C-clamp, that'll ruin the caliper.
If you've done brakes with floating calipers before, this one will be familiar to you. Clean up the caliper slide pins so they work nice.
Make sure the new pads fit nice into the caliper bracket. Sometimes I have to file the pad's steel backing plate so they don't wedge themselves too tightly.
SKHEMR Aug 25, 2006 02:38 AM
RE: is this a pain?
That is correct. All you need is something to rotate it with, it's shaped like a T. I use something flat like a thick mental ruler.
dnsw24 Aug 26, 2006 10:33 PM
RE: is this a pain?
thanks guys
fireballer44 Aug 26, 2006 11:43 PM
RE: is this a pain?
ORIGINAL: SKHEMR
LOL...I had to point out the mental ruler......just kidding around you know, I am sure it was just a typo.
I am curious, what is the floating caliper design?? It might be a term for something I already know about, is it something my 1991 would have??
JimBlake Aug 27, 2006 10:59 PM
RE: is this a pain?
ORIGINAL: fireballer44
All the Hondas I know have floating calipers. There's no outboard piston, & the entire caliper slides in & out on its slide pins. So the outboard part of the caliper is simply a sort of hook that pulls the outboard pad in against the rotor.
fireballer44 Aug 27, 2006 11:50 PM
RE: is this a pain?
Ahh, I understand now. So I guess every disc brakes I have ever replaced had these floating calipers, because I only remember doing those with one piston.
Now I know what it is officially called :D
