-   -   possible DIY? (https://www.hondaaccordforum.com/forum/general-tech-help-7/possible-diy-18350/)
bikener May 8, 2008 08:32 AM
possible DIY?
So my clutch is starting to slip.. that sucks. I've go very little knowledge about clutch work but my dad sais he could probably do the labour. Would it be possible for two noobs (me and my dad) to replace the clutch in my 1990 accord if we did any required research for the job? How hard is it to replace the clutch?
BlkCurrantKord May 8, 2008 09:40 AM
RE: possible DIY?
Should be possible for both of you to do it granted you have all the necessary tools. Replacing the clutch is a fairly labor intensive job, you have to drop the trans.
00AccordLX5spd May 8, 2008 01:55 PM
RE: possible DIY?
As BKC said, the entire transmission must be dropped/removed to work on/replace the clutch. The car will need to be lifted off the ground enough to get the trans dropped to allow access to the clutch. Unless you want to remove the engine instead...
falkore24 May 8, 2008 02:19 PM
RE: possible DIY?
Dropping the tranny is a lot easier than pulling the engine.
00AccordLX5spd May 8, 2008 03:29 PM
RE: possible DIY?
ORIGINAL: falkore24
Oh really? **sarcasm**
finch13 May 8, 2008 03:57 PM
RE: possible DIY?
ORIGINAL: 00AccordLX5spd
ORIGINAL: falkore24
http://sf.startupweekend.com/wp-cont...7/11/o_rly.jpg
I am going to be changing the clutch and flywheel here as soon as I get my exchanged clutch disc back from Fidanza. I can let you know how difficult it was to do. It's not going to be performed on a lift or anything, just jackstands and tools, FTW.
00AccordLX5spd May 8, 2008 04:52 PM
RE: possible DIY?
ORIGINAL: finch13
DIY with pics!! That would be a nice edition to the DIY section!
Do it or ban http://www.6thgenaccord.com/forums/i...ilies/whip.gif
finch13 May 8, 2008 04:55 PM
RE: possible DIY?
I can try... my Grandpa gets fussy over wasting time though... wouldn't want to support those ricer hooligans! lol. I will see what I can do though.
falkore24 May 8, 2008 05:10 PM
RE: possible DIY?
Don't get the camera greasy!!!
WheelBrokerAng May 9, 2008 12:13 AM
RE: possible DIY?
But if you do, make sure you use windex cleaner and a Soft Cloth;)
