POWER DOOR LOCKS
Old Nov 15, 2007 | 10:56 AM
JBLAZE@HYPER16VALVE's Avatar
Default POWER DOOR LOCKS
Hello everyone. I have a...
1996 Accord Ex 2dr couple...5spd
I have been getting this annoying mechanical noise from the power door locks ever since I swapped out the driver side door for another one. I'm not sure if the alignment of the door has anything to do with it. It just happens most of the time when i'm driving making this buzzing noise and if I keep the lock latch unlocked, it will automatically lock...but after, it will continue to make that buzzing noise. When I turn off the car, it sometimes will make the noise a couple of times before it stops. It's as if the power door locks continue to cycle trying to lock the doors. I've look around and heard about the actuator or something like that. Could someone please help me out??...
THANK YOU in advance.
Old Nov 15, 2007 | 11:00 AM
blackex19's Avatar
Default RE: POWER DOOR LOCKS
im thinking a bad relay?
Old Nov 15, 2007 | 11:06 AM
sir_nasty's Avatar
if it was an alignment issue the door wouldn't close properly, sounds like it could be the door lock acuator.
To confirm that it's not a door alignment issue, try locking the door with it open.
Old Nov 15, 2007 | 12:24 PM
thanks guys...please continue the input...I will try locking the door while open later... where could i find the relay?...I'm sure that little black box has nothing to do with it because the power door lock was perfectly fine before i put it in mine. Under what section could i locate the relay in the manual provided by desert storm?
thanks.
Old Nov 15, 2007 | 12:31 PM
sir_nasty's Avatar
I'm leaning strongly towards the actuator.
Old Nov 15, 2007 | 01:25 PM
deserthonda's Avatar
get the old door lock actuator out of the old door and install it on the new ( used ) door
Old Nov 15, 2007 | 03:04 PM
could someone please provide a pic of what the actuator looks like? thanks.
Old Nov 16, 2007 | 11:24 AM
Does anyone have a detailed wirte up on replacing or repairing the actuator?
trukid21
Jul 29, 2011 09:43 PM
Antarctica
Oct 5, 2010 08:33 PM
ukatusa
Jun 12, 2008 09:41 AM
abhanu
Mar 31, 2008 11:02 AM
honker3
Dec 29, 2007 01:37 PM
