-   -   Power Mirror Gremlins (https://www.hondaaccordforum.com/forum/general-tech-help-7/power-mirror-gremlins-19285/)
chestah cheetah Jun 23, 2008 12:39 PM
2000 Accord EX Coupe
Newbie here. Wanted to descibe an issue so see if anyone has any insight:
Replaced the drivers side mirror, motor module, and wiring harness. Put everything back together and now the mirror positioning switch on the door panel is only capable of moving the mirror to the left. No up, down, or right functionality. The issue has also spread to the passenger side. Before I installed the new parts, I did "mock up" the new motor module to the old wires and the whole thing worked fine. Anyone have a guess? Thanks.
HondaPhyco Jun 23, 2008 12:55 PM
RE: Power Mirror Gremlins
recheck wires and make sure they are connected right.
chestah cheetah Jun 23, 2008 05:51 PM
The new kit came with a new wiring harness with slightly different colors. I wired like this:
Yellow to Yellow
Gray to Gray
Dark Gray to Black
HondaPhyco Jun 24, 2008 10:02 AM
wierd but i would try switching the dark grey and blak just tosee the out come you never know. but wit aftermarket stuff it never matches up to factory perfectly.
falkore24 Jun 24, 2008 11:48 AM
If it all worked properly before you put everything back together, then you pulled on a wie when you were reassembling the door. Check the wires again.
