-   -   Power Outlets Stopped Working (https://www.hondaaccordforum.com/forum/general-tech-help-7/power-outlets-stopped-working-64953/)
OneLuckyGuy Aug 28, 2017 05:15 PM
2003 Accord both power outlets stopped working. I checked the fuse and it was blown and I replaced it. Both power outlets still did not work. I tried another fuse and they still did not work. :confused:
redbull-1 Aug 28, 2017 09:05 PM
You need to check both under-dash Fuse No. 9 (15A) and Fuse No. 32 (7.5A).
Power (+) via Fuse No. 32 and the separate ground (-) source are used to energize coil in the accessory power outlet relay, which allows power (+) via Fuse No. 9 through the relay to the respective accessory outlets.
OneLuckyGuy Aug 29, 2017 01:35 PM
Thank you redbull-1
I checked 32 and it was good and even put a new fuse in and that didn't help.
PAhonda Aug 29, 2017 10:18 PM
Do you keep blowing fuses?
dgp1961 Aug 30, 2017 10:57 AM
Wife lost power in one outlet, replaced the fuse worked ever since...:confused:
OneLuckyGuy Aug 30, 2017 09:21 PM
I replaced the fuse # 9 15 amp fuse once afetr it had blown. That didnot solve the problem. I checked the 7.5 amp #32 fuse and it was good. I even put a new fuse in and that didn't help.
poorman212 Sep 2, 2017 05:45 AM
About the only thing left is the relay :shrug: or a wire issue.
