-   -   Power Steering Problems 2000 Accord lx (https://www.hondaaccordforum.com/forum/general-tech-help-7/power-steering-problems-2000-accord-lx-33927/)
Mr.Project8 Jul 31, 2010 05:11 PM
Power Steering pump is making alot of noise it went out about a month ago or so.....Can i just replace the pump or do i have to replace the entire unit Hoses, pump, bleeder screws? My first doing this on my own as well. Is it difficult, will i need professional help? Need Advice
(Oh and on a side note opinions on EBC Brakes Message me plz!)
JimBlake Jul 31, 2010 07:17 PM
V-6 or 4-cyl engine? (LX-V6 cars apparently exist)
Before you replace the pump again, try to check or rule-out bad hoses or bad seals. The pump suction hose (low pressure) might be leaking & the pump sucks some air & that causes it to make noise.
The reservoir has a fine mesh screen down low where it's always submerged. If that screen is dirty & clogged, that can also lead to a noisy pump.
You should be able to unbolt the pump & replace it. The low pressure hose comes off with a hose clamp. The high-pressure hose unbolts - get a new O-ring so it doesn't leak when you put it back on.
http://www.hondaautomotiveparts.com/...8401_b3360.png
Mr.Project8 Aug 4, 2010 10:18 AM
Its a 4cyl. And i had it diagnosed by Honda and they told me it was the power steering pump. It makse alot of noise not only when im turning also a lot of noise comes from the belt. Also power steering fluid spews out of the reservoir whenever theres any in it....Anyway i didnt wanna spend $400 getting the dealer to fix it. But what about the belt do i need to replace that as well?
JimBlake Aug 4, 2010 08:07 PM
For the price of a belt, I think it's a bit silly to put the OLD one back on. YMMV...
Mr.Project8 Aug 5, 2010 10:33 PM
i figured...it was just me being lazy.....and a little cheap..lol Appreciate the help
