Power Window won't go down, just click sound
I have a 1999 Honda Accord EX and it has power windows. Suddenly one of the power windows has stopped going down and when i press the button (the driver's side button for the passenger's side windows or the passenger's side window), i just get a click sound on the passenger side window, but it does not go down.
Additionally the driver side window, while going down, makes a grinding sound which is kind of scary. Please tell me what may be the issue ?? |
Just back from Firestone and they charge a freaking 99$ just to check one door. This is expensive.
What other options to get this thing checked and fixed ?? |
Windows are dragging heavily and perhaps misaligned. Driver's regulator may be damaged.
You will need to remove door panels and investigate further. Any experience w/ DiY? good luck |
Absolutely no experience with DIY so that option is out of scope. The firestone people quoted 99$ for checking each window (remove door panel etc etc) :O
This can be labor intensive, if they are inexperienced. I would suggest doing some checking for someone familiar w/ honda power windows. Body shops may be a good option.
good luck |
^^You seem to be from TX, can you suggest any place in Dallas(specifically Plano area) ??
I don't know anyone.
Suggest investing in Angies List membership and look for shops in your area w/ A rating and at least 10 reviews. good luck |
