-   -   Problem Bleeding Brakes... (https://www.hondaaccordforum.com/forum/general-tech-help-7/problem-bleeding-brakes-20032/)
corr04 Aug 9, 2008 07:31 PM
My 96 Accord lx 5 sp. needs the brakes bled. The problem is I broke off the left rear bleed screw trying to loosen it. None of it is sticking out so I cant get a grip on it what so ever.
Is it possible to loosen the brake hose/nut that goes into the back of the hub and bleed it that way? I have tried a few times with no sucess.
Or does anyone have any tips on removing the broken bleed screw? Any help is much appreciated. Thanks in advance!
-corr04
PAhonda Aug 9, 2008 07:53 PM
RE: Problem Bleeding Brakes...
You will not be able to bleed by removing the hose from the back of the caliper. Go to parts store and get a new bleeder valve.
An easy-out should get that out.
