Quick help for this one. Inline transmission filter.
Greeting HAF!
After replacing my inline trans filter, i am not sire if i pit the new one correctly. I have photos for you guys to look at. Please let me know if the flow is correct. https://fbcdn-photos-a.akamaihd.net/...121_n.jpg?dl=1 https://fbcdn-photos-a.akamaihd.net/...692_n.jpg?dl=1 https://fbcdn-photos-a.akamaihd.net/...065_n.jpg?dl=1 Thank you once again HAF. |
2 Attachment(s)
I can't find a good diagram for the 5th gen 4 cyl auto to be able to tell?
I found something for the 6th gens but I'm worried it is not good info. Can you remove the filter and crank then engine over - disable fuel or spark so the engine will not stat and see which hose "pushes" fluid out? Also, I can't tell from the pic's but I hope you used hose that is rated for trans use....Regular fuel line hose SHOULD NOT be used for this. Attached is the flow for a 6th gen (98-02) 4cyl auto. |
