Radiator Fan Not Coming On
93 Honda Accord check engine lite was on replaced engine temp sensor, that fixed the the check engine lite, now the radiator fan does not work any ideas thanx
Most likely radiator fan motor has failed. Try thumping the motor housing firmly w/ AC and keyswitch On. If fan comes on briefly, the brushes are worn out and a new fan motor is needed.
If no response, remove the connector to the fan and check for 12V. If you have 12V the fan motor is dead and must be replaced. If you don't have voltage, the radiator fan relay and fuse 21 in under hood fuse box should be checked. good luck |
the 20 amp fuse is bad going to put a new one in shortly thanx for the info
Failed fuse may be an indication of motor problem. If it fails again, a new motor is indicated.
good luck |
