-   -   Radiator fans (https://www.hondaaccordforum.com/forum/general-tech-help-7/radiator-fans-20382/)
kornbln Aug 28, 2008 07:12 PM
Radiator fans
I just replaced the radiator on a 97 Accord (had a leak). Instructions I found online said to put the coolant in, turn on the engine and let it run until the radiator fan comes on twice. I let the car run for a while and it never came on. So I took it for a drive and everything seemed to be running good. No leaks, good temperature. The A/C fan comes on when I turn the A/C on (standing in front of the hood, the one to the left next to the overflow reservoir), so I know that one is working...But the same fan comes on automatically after I park the car. Shouldn't it be the other fan coming on?
PAhonda Aug 29, 2008 01:15 AM
RE: Radiator fans
The driver's side fan is technically called the a/c fan, and the passenger side fan is the radiator fan. I know that both should turn on when the a/c is on.
kornbln Aug 29, 2008 01:18 AM
RE: Radiator fans
PAhonda,
Yeah I just read that both should be running when the A/C is one. They aren't. What should I check?
cabinhill Aug 30, 2008 08:07 AM
RE: Radiator fans
Check the fuse for the radiator fan. If its good check for voltage on the connector to the fan.
PAhonda Aug 30, 2008 02:16 PM
RE: Radiator fans
Either the fan isn't getting power or the fan is shot. The quickest way to determine the problem is
Unplug connector to non-working fan, turn on car and a/c. Stick a volt meter on the two leads.
If you have 12V, replace fan. Iif you smack to motor with the handle of a screwdriver and the fan turns on, the fan motor is definitely shot.
If no voltage, then something electrical is the problem upstream.
