| Mason James Mattias Roberts |
Jul 26, 2015 08:32 PM |
Random, RPM drop even with gas pedal down
This is a very specific problem im having that i am completely unable to find any reference on. I already have a thought as to the cause, but here are the symptoms. It has only happen TWICE since ive owned this 95 Accord EX Coupe Manual 5 speed. While driving, both times in 1st to 3rd gear in the city moving pretty slow, both warmed up and cold, the car will drop to 1500 rpm and the gas pedal does nothing. By nothing i mean, to the floor or all the way off, it changes nothing, as if its disconnected. Give it about 5 to 10 seconds, and its back to normal. The first time a year ago, happened once and went away. Now, a week ago, it did it twice in the length of about a minute. Throttle body is after market billet, new TPS correctly plugged in, newer MAP sensor with spliced wires as the last one was falling apart at the end of the plug. But most importantly i think, the fuel line right before the filter is twisted down on itself from a bad attempt to remove the fuel filter about 2 years ago. This i think is the likely cause. I have a plan to replace the fuel line, pump, and sender already, but im trying to verify if any one else has dealt with this nonsense. If you want more info, just ask. It has a long history of my repairs and maintence.
