Rear Defrost Fix
I have a 94 EX that i had the windows tinted to. Every defrost line worked before the tint, but now one does not. i bought a defrost repair kit, but am hesitant on if it will work or how it will look with the tint.
Has anyone done this or had a similar problem? |
If only one defrost line is not working and you can see well out the back window, is it worth trying to fix or possibly causing more problems.
I am not sure what is involved with the repair kit, the shop that tinted the windows might know for sure though. |
You have to remove the tint to repair the line... or at least cut a strip out to repair it.
Thanks - yep i will just live with it. it sucks because i knew it was going to happen. they all worked before the tint and even after they first put it on, but they had a couple bubbles that i made them fix.....well what do you know...once i had them fix it one row doesnt work. The big thing is that i don't have time to complain about it and make them fix it, plus its kind of hard to prove on a car that is 15 years old. o well, kick a stone a move on.
