-   -   removing plastic cage for rear lines? (https://www.hondaaccordforum.com/forum/general-tech-help-7/removing-plastic-cage-rear-lines-65806/)
spacechimp Jun 2, 2018 10:57 PM
HAVE to replace rusted brake lines and I've removed the plastic nuts from the cage that holds the brake lines and fuel lines.
I can't really SEE how the cage comes apart so I've tried everything with a screwdriver and got NOwhere.
I've searched google and youtube and here. No good info anywhere.
GOTTA get this damn thing open so I can splice in new lines
2001 4dr 4cyl atx
any Ideas?
THANK YOU!!!!!!!!!!!!!!!!!!! :confused:;)
redbull-1 Jun 3, 2018 02:14 AM
See if this thread may give some insight:
https://www.hondaaccordforum.com/for...e-lines-38250/
and this other link (post #10):
https://honda-tech.com/forums/honda-.../#post51407778
https://cimg2.ibsrv.net/gimg/www.hon...ef62c9871a.jpg
spacechimp Jun 3, 2018 09:05 AM
Excellent diagram..
like like 36 are the bolts that hold it all up although i see mention of clips and i have no idea where they are or how to undo them.
Will crawl back under there and take those bolts off.
THANKSSSSSSSSSSSSSSSSSSSSSSS:D
The Toecutter Jun 3, 2018 12:24 PM
Originally Posted by spacechimp (Post 380695)
Excellent diagram..
The clips attach to the lines themselves.
Keep in mind you might want to look ALL of the lines over real good. I only say that, as I was in there on my wife's 00 Accord, to fix a brake line, and replaced all of the lines after the rust fell off and exposed more holes.
JimBlake Jun 4, 2018 08:55 AM
Keep in mind the plastic stuff is 17 years old and will probably be brittle. Be prepared to buy some parts that will break as you dismantle it.
The Toecutter Jun 4, 2018 12:24 PM
Yup. Zip ties become your new friends.:D
rikkitikki Jan 28, 2022 10:41 AM
(10) 10mm bolts hold the tray in place. the bolts on the end are pretty impossible to get to without getting under the car (chock your wheels!). if they rusted you can get a bolt extractor kit (local lowes sold it for 20) or drill it out.
