Replacement Wheels for '94 Accord LX Sedan
Hello,
I'm looking to purchase a replacement set of wheels for my '94 Accord LX sedan. I found a pre-owned set that was originally stock on a Nissan Versa which has the same bolt pattern, but different hub center bore size. Whereas the Accord's stock wheels have a 64.1, the Nissan Versa's is 66.1. Will the Nissan wheels fit on my Accord? Thanks! |
Since center hole is larger they should be OK. Sometimes the lateral position of wheel relative to centerline is offset either inwards or outwards. This might be an issue w/ steering if there's a difference. A side/side comparison of wheels would probably highlight any problems.
good luck |
(Post 351051)
Could you clarify what you mean by "lateral position of wheel relative to centerline" please? Also, what exactly am i looking for when I do the side-by-side comparison? |
What I mean is lateral offset of tire center from wheel center. You see extreme examples on lifted trucks where they offset the rim to the vehicle outside to avoid wheel well issues.
Rim width (assuming you want same size tires as Accord), rim diameter (same reason), bolt pattern centerline, stud holes, lateral offset if any, center hole (larger should not be an issue). good luck |
