Replacing 88 Fuel Tank
The fuel tank to my 88 Accord just started leaking at the seam. There is a trail of gas everywhere I go. Some help on replacing the fuel tank would be appreciated. I plan on doing this at home. Thanks in advance.
RE: Replacing 88 Fuel Tank
I've never done it myself but here's the teardown instructions! Drain the tank first.
[IMG]local://upfiles/3079/5E0E1153B0C346D3950A8A0A85B294C2.jpg[/IMG] |
Thanks
it is a very easy job to do,,,,,,,,,,a lot easier if tank is almost empty , it will weigh less ,,,,,,,,,
Make sure to disconnect all the wiring and hoses, fuel line , from the top side ,, fuel pump and sending unit wiring you do that from inside the trunk, remove the 2 access covers ( under the trunk mat) ,, |
| All times are GMT -5. The time now is 08:37 AM. |
