replacing ps pump belt
need info on replacing the ps pump drive belt on a 96 accord v6. a manual or instructions on the steps i need to take to remove the old belt.
thanks for the info |
RE: replacing ps pump belt
Loosen the tensioner bolt then the bolts holding the pump to the pump bracket. Keep loosening the tensioner bolt until you can slide the belt off the pulley. Install the new one is reverse order. Put tensions on the belt so you can push the belt 1/4" if the space between pulley's is around 7 in. and 1/2" if the space is around 13 in.
| All times are GMT -5. The time now is 09:50 AM. |
