Rocker stud torque specs?
Old Jan 8, 2010 | 01:30 PM
Camryn's Avatar
Default Rocker stud torque specs?
Well I'm not sure if this is the right section for this thread, and if it isn't, I apologize.
I recently bought a 93 accord se automatic (f22a6) and a valve cover stud is broken(the one that goes through the rocker shaft), so I bought a new one and haven't been able to find how much to torque it to at the rocker shaft.
Also if there is a certain pattern I should torque the studs below the valve cover and the actual valve cover bolts that would be greatly appreciated so this doesn't need to be more of a hassle than absolutely necessary.
Thanks.
Old Jan 8, 2010 | 01:54 PM
This IS the right section.
Go to the DIY section & look for a sticky thread about links to shop manuals. The manual will have that information. The tightening torque is kinda low, and I'm pretty sure there is a proper sequence for those bolts.
adonus348
Nov 30, 2011 11:49 AM
theirlaw
May 8, 2009 01:14 PM
Mike 68
Dec 19, 2008 10:33 AM
Pauls95
Apr 25, 2007 08:58 PM
MALSR
Sep 26, 2006 08:58 PM
