Rough idle (low) 1991 Accord 2.2
Ok I tried to figure out when it does it but I can’t it’s to intermittent what’s all the stuff to check again and what’s the idle supposed to be….it is a bit worse now that I got the a/c working. But sometime it’s ok, and sometime if you put it in neutral it goes up them drop it in gear and it stays good …. Sometime …lol.
Mike Kozura |
mike try ajusting the idle screw.
Don't mess with the idle screw.
Clean the throttle body and both sides of the throttle plate. Then clean the IACV screen. |
