Rough shift when cold
Hey Everyone,
I have a '99 Accord with the V6. I recently rebuilt the transmission at 158,000 miles and everything has been working great, and still is for the most part. I have an odd issue with the 1-2 shift when the engine has just started and is cold. The transmission will slip/hesitate when shifting from 1st into 2nd gear. It's worse when turning out onto a street and accelerating. When accelerating straight you do not notice it, and once the engine warms to operating temperature the issue is completely gone. I use genuine Honda fluid (although they changed their formula!) and the level is right where it should be. All of the solenoids and pressure switches were replaced when I rebuilt the unit, and all clutch packs were measured and within proper tolerance according to the manual (and by "within" I mean in the middle, not at one end or the other of the spectrum). I am pretty nit-picky too and made sure every nut and bolt was torqued properly as per the manual. Any ideas would be helpful! |
Tough being a nit-picky guy, but congrats on the rebuild.
I'm leery of trying to fix things that are 99% OK, so thought here is --> install a remote starter unit and let it warm up for 5 minutes before you leave the house in the AM; might have comfort benefits as well. OK shoot me. |
Originally Posted by UhOh
(Post 262511)
I should also mention I now have just over 169,000 miles on the car since rebuilding the trans. |
Transmission is going out...happened on my 01, the diff went out ...eventually it will do it all the time.
| All times are GMT -5. The time now is 10:31 AM. |
