RPM's Drop After Engine Start
'01 EX, V6....Engine starts fine, but right after ignition the rpm's drop nearly to the point of engine dying, then slowly recover to normal idle. A/C is not on at this time.
Any ideas?? |
RE: RPM's Drop After Engine Start
clean your ICV and see if that fixes the problem. Also clean the TPS sensor along with the intake
okay so I've had WAY to much caffiene today.... what do you mean by ICV?
are you talking Idle Control Valve? do you know where that's located on a 01?
well since my car is in the shop I cannot look but I can tell you tomorrow when I get it back
I can almost hear the underlying tone of mass amounts of profanity mixed in with the words "shop" and "transmission" in that post *LOL*
The idle air control valve (IAC) is bolted to the bottom of the throttle body.
| All times are GMT -5. The time now is 05:17 AM. |
