rpms go crazy
when i accelerate hard, and get around 5000-6000 rpms, the tach jumps everywhere. why is this?
RE: rpms go crazy
mine did this a while ago and it was a loose connection in the distributor................and thats redline on a stock accord so why does it matter? lol
RE: rpms go crazy
i checked, it is all good and tight. :)
RE: rpms go crazy
For your year/engine, the tach signal comes from the ignitor (inside the distributor). So check connections again.
RE: rpms go crazy
I've seen spark breakdown due to bad plugs also cause rpm fluctuations (94 Accord EX). This is not good for ignitor or coil. Clean and regap or replace plugs. Also check wires for arcing w/ water mist sprayed at night. Any visible arcing indicates wires are cracked.
good luck |
| All times are GMT -5. The time now is 02:06 AM. |
