-   -   s light code flashes 9 times and check engine light flashes 2 times (https://www.hondaaccordforum.com/forum/general-tech-help-7/s-light-code-flashes-9-times-check-engine-light-flashes-2-times-15750/)
ddold@gkschools.org Jan 28, 2008 03:33 PM
i have a 1990 accord ex 4 door and i checked the code by jumping a wire on connector but i cant find the page that tells what they mean? can you help sir nasty or desert honda thanks dan
sir_nasty Jan 28, 2008 04:32 PM
RE: s light code flashes 9 times and check engine light flashes 2 times
It appears to be either an O2 sensor or the VSS, does your cruise/speedometer work? What's the car doing?
sir_nasty Jan 28, 2008 04:36 PM
is the code 9 just 9 short flashes repeated?
TexasHonda Jan 28, 2008 08:58 PM
Code 9 is NC Speed Sensor electrical fault; coupler, wiring, or sensor. This is not the Vehicle Speed Sensor. It may be a similar type of sensor.
Two flashes should be two long flashes for code 20, since there is no Code 2. Code 20 is electronic load detector circuit fault.
ddold@gkschools.org Jan 29, 2008 06:05 AM
the speedo works after replacing gauges cruise works fine.Car runs ok but trans shifts hard and downshifts hard.I don't know if thats related to the lights or not. I think it is 9 short flashes on the S light
TexasHonda Jan 29, 2008 11:50 AM
The trans code 9 is 9 short flashes on S-light, as explaned above.
PAhonda Jan 29, 2008 03:35 PM
On the TCU: 9 is the NC speed sensor. If you go to the DIY section, there is a link for online manuals. You can download a 91 shop manual as a pdf. The electrical test for the sensor is on page 9-40 and the location of the sensor is on 9-23.
recheck the ECU code. In that 91 service manual, there is no code 20.
