Shift Solenoid B Removal, 2016 Accord V6
Old Feb 18, 2024 | 10:17 AM
Twnealjr's Avatar
Cool Shift Solenoid B Removal, 2016 Accord V6
Hello all, this is my first post to this site. My daughter’s 2016 Accord V6 Touring with 55k miles is throwing the ‘P0756 shift solenoid B stuck open’ error code and the transmission is in limp mode. I was able to free it up a few times by tapping the solenoid with a wrench and the codes would clear and the car would drive normally but this no longer works. I did a 3qt fluid change with Honda ATF DW1. The drained fluid was a bit dark but I did not find any metal and the plug only had the normal amount of shavings on it. Has anyone here replaced the B solenoid on this generation Accord? I would love to see pictures, videos, part numbers, or anything else. 😉. I can’t find hardly anything via google search.
Thank you,
Tommy
Old Feb 18, 2024 | 10:44 AM
It is part of the secondary valve body assembly. The shift solenoid B is not sold separately.
https://www.hondapartsnow.com/genuin...0-5b7-000.html
Old Feb 18, 2024 | 11:13 AM
Twnealjr's Avatar
Thank you so much. It doesn’t even look like I can buy that part now due to manufacturer’s shortage. Darn.
trey28
Aug 2, 2020 12:15 PM
Terry Williams
Jun 26, 2017 05:49 PM
Edgar in Atlanta
Jan 24, 2016 09:28 AM
