Shifting to 3rd gear grinds
I have a 1998 Honda Accord DX 2dr Hatchback that has 250,000 miles on it with a 5 speed manual transmission. When I shift from 2nd to 3rd I hear a grinding of gears.
I've adjusted my clutch so it disengages the clutch totally when the clutch pedal is depressed normally. Same issue. Then... I replaced the (transmission) gear oil (it was low) with 85w-140 and it has reduced the grinding into 3rd gear somewhat. Also, if I let the engine RPM go down to below 2000 RPM and then shift up to 3rd gear I don't get any crunching/grinding sounds. All shifting into any other gear is just fine. Any suggestions? email J.R. at jr_sanford@yahoo.com if you've got any solutions. Thanks, J.R. Chehalis, WA |
RE: Shifting to 3rd gear grinds
What year, trim, motor etc are we talking about? We can assume that it's an accord but we need a little more information than that to answer this properly... And unless I am mistaken I don't recall any of the accords using gear oil in the transmission....
Put the car info in your signature and it will be there everytime you post |
ORIGINAL: jr_sanford I've replaced the gear oil with 85w-140 and it has reduced the grinding into 3rd gear somewhat. Also, if I let the engine RPM go down to below 2000 RPM and then shift up to 3rd gear I don't get any crunching/grinding sounds. All shifting into any other gear is just fine. Any suggestions? email J.R. at jr_sanford@yahoo.com if you've got any solutions. Thanks, J.R. Chehalis, WA |
Easy there velocifero! http://www.6thgenaccord.com/forums/i...ilies/whip.gif
He's new to the forum....cut him a little slackhttp://www.6thgenaccord.com/forums/i...ilies/lawl.gif |
snychro sounds like its headed south...replace that and new fluid and should take care of the problem...my 91 is doing the same thing
ORIGINAL: 00AccordLX5spd Easy there velocifero! http://www.6thgenaccord.com/forums/i...ilies/whip.gif He's new to the forum....cut him a little slackhttp://www.6thgenaccord.com/forums/i...ilies/lawl.gif |
Double clutching will allow you to avoid grinding until you fix the synchronizer. As you shift you pause in neutral, release the clutch, re-engage the clutch and shift up. Not exactly speed shifting, but easier on the nerves.
good luck |
[quote]ORIGINAL: jr_sanford
. I replaced the (transmission) gear oil (it was low) with 85w-140 email J.R. at jr_sanford@yahoo.com if you've got any solutions. Thanks, J.R. Chehalis, WA [/quote replace that 85w oil with honda fluid or at least 10w-30 oil,, otherwise it will burn up the 5th gear assembly 85w it too tick to lubricate 5th gear.. also,, you ask us to E-mail you ?? are you for real ?? like it was stated , you like answers , come back here also,, it sounds like the syncro is worn .. |
ORIGINAL: Velocifero ORIGINAL: 00AccordLX5spd Easy there velocifero! http://www.6thgenaccord.com/forums/i...ilies/whip.gif He's new to the forum....cut him a little slackhttp://www.6thgenaccord.com/forums/i...ilies/lawl.gif |
| All times are GMT -5. The time now is 07:30 AM. |
