shudder at constant 2200 rpms?
95 Accord EX, 2.2, Right around 2200 rpms I get a shudder, it goes away if I drop below or go above, but comes back as soon as I try to maintain close to that rpm. Pulled the plugs and they looked good, gaps were fine. Any ideas?
Probably need to clean the EGR ports. Pretty simple DIY. Google T2T013.pdf. the last two pages show the 94-97 accord procedure.
Searching found me that, but it sounded more like under acceleration, whereas mine is constant speed. Plan on trying it this weekend.
Thanks |
thanks, that seemed to fix it.
Thanks. Lots of times we never find out whether our advice was any good.
3 of the 4 were clogged, nothing very hard to remove, if i hadn't damaged 1 o ring, I would have been done in under an hour.
