Sideview Mirror Tightening
I am having a problem that my driver's sideview mirror is loose where it folds in. The power function is working fine and a dealer told me it had to be comletely replaced but I have alot of doubts about this. It seems that you should just be able to tighten up the mechanism so it sits tighter. Any advice???
RE: Sideview Mirror Tightening
ORIGINAL: wkugler I am having a problem that my driver's sideview mirror is loose where it folds in. The power function is working fine and a dealer told me it had to be comletely replaced but I have alot of doubts about this. It seems that you should just be able to tighten up the mechanism so it sits tighter. Any advice??? If you look up from the bottom of the mirror there are 2 holes, use a phillip screwdriver and see if the screws are loose,, if not , it is mirror time |
Is there a safe way to pop off the 1"X3" access plate under the mirror assembly to get at the screws?
