-   -   Slow Acceleration/Shaking (https://www.hondaaccordforum.com/forum/general-tech-help-7/slow-acceleration-shaking-55080/)
frankiep17 May 31, 2013 02:41 PM
Hey guys my 91 Accord (automatic transmission) started shaking about a month ago. Since the car is running and we are about to buy a house I decided to hold off on replacing the EGR valve, I say EGR valve because that is the answer I found in most of the similar blog posts. I did replace the fuel pump though and there was no noticeable improvement. But about a week ago I started to get slow accelerations out of stops when I was in D4. If I bring it down to 1 it accelerates much better but there seems to be some kind of clicking noise coming from under the car. I tried to pull a code from the diagnostic terminal using a paper clip but the check engine light stays ON when I turn the key to the on position. So I figured I'd start to look for help before something else goes wrong. Any advice is greatly appreciated.
almightyemu Jun 1, 2013 08:45 AM
It sounds like you've got a misfire of some sort - there're so many things that could cause misfires that it's pretty much impossible to give you any direction without knowing what DTCs are being thrown for the MIL. Is it a random multi-cylinder misfire or one from a specific cylinder? EGR will normally throw its own code, too, if its stuck.
poorman212 Jun 1, 2013 01:06 PM
And I'd ask about the normal tune up items (cap, rotor, plugs, inspect wires, ect).
Also note the the egr is "not in play" when the engine is cold - it does not go into closed loop until the engine is at op temp.
