Smaller Size Tires
Hello out there, being a cheap kind of guy, I got a deal on four 14" snow tires for my 2002 Accord (4 cyl) and since there are 15" tires on there now, someone is telling me I'm gonna have engine, computer, tranny (auto) problems. Other than speedo and milage reading being a little off, any had experiance with this ?. Any help is appreciated. Thanks
Chuck |
RE: Smaller Size Tires
Never heard of this, and know a ton of people running different than stock rims and tires including myself. I wouldnt worry about it.
With a 2002, you MIGHT(?) have brake clearance problems. I think maybe 15 inch was the smallest stock size?
Please make sure that you post your nexts posts in the correct forums...I moved you to this one..Welcome to the HAF...
WheelBrokerAng [sm=americanasmiley.gif] |
ORIGINAL: JimBlake With a 2002, you MIGHT(?) have brake clearance problems. I think maybe 15 inch was the smallest stock size? Go to miata.net/garage/tirecalc.html to compare the two. |
As long as they fit over the brakes, its OK. Your ABS might have problems, ONLY if you have different sizes on different corners.
I think it all comes down to the circumference difference between the tires. If there is a difference then you will see a speedo difference. I doubt you will have any trans issues or ABS issues. Ireally can't see how there could be any problems at all unless the brake calipers won't clear....
Well I hope you got some 14" wheels for those tires cause you sure cant put 14" tires on a 15" wheel.
For a quick test just stand one of the snow tires next to the 15" thats on there now, if it is within about a half inch of being as tall(profile) you wont notice any problem. |
