Spark plugs and wires for 89 Lxi
I just purchased a 1989 LXi accord and I want to change the spark plug and the spark plug wires. Which ones do you recommend? I was looking into the NKG, I used them on my focus and I really liked them. Would these work ok with this accord (it has like 202000 miles on it) and which spark plug wires would you recommend. Thanks
RE: Spark plugs and wires for 89 Lxi
Here's a link for you listing the plugs NKG mkaes for you: http://www.ngk.com/results_app.asp?AAIA=1167027
Accel makes a set of 8mm wires for your engine. I'm not sure if they make them for your engine, but Nology 10mm wires I've had good history with. |
use NGK plugs BPR5EY-11 .. and as for plug wires ( trust me on this one) use Honda factory plug wires
Thanks for the info, I will get the parts and change them.
