Speedo works intermitten
Hello fellow Honda owners, I am back with another Honda issue. My 1990 Accords speedo works when it wants to. One minute I am drivin, works fine, then it drops to zero. Most of the time, the S light will start flashing shortly after. Any ideas? Thanks
RE: Speedo works intermitten
Vehicle Speed Sensor is the first thing I would check since your speedo quits and your S light begins to blink
ORIGINAL: YeuEmMaiMai Vehicle Speed Sensor is the first thing I would check since your speedo quits and your S light begins to blink |
Problem is the speed sensor, howerver I don't have $140.00 bucks to replace it so I will just live with it for a while. Or at least until it quits all together. Thanks for your help.
you can remove disassemble clean and regrease with high temp diaelectric grease and reassemble. should fix your problem
Ok, thanks.I will give that a try this weekend.
| All times are GMT -5. The time now is 08:38 AM. |
