Speedometer failure
Old Aug 30, 2004 | 09:22 AM
UnitedAuto
Default Speedometer failure
i have a 1996 accord and the speedometer only works some of the time. someone suggested that it was a problem between the ecua and the speedometer.
Does anyone know how to fix this problem?
Thanks
Old Aug 31, 2004 | 02:27 AM
omaleem
Default RE: Speedometer failure
bobby? United Auto, Inc.?
Old Aug 31, 2004 | 09:31 AM
UnitedAuto
no
Old Sep 8, 2004 | 08:30 AM
n0rms
I actually have that same problem. About 3 months ago, my speedometer just failed on me, and it will stay at around 20MPH when its not working. It's definitely something with the speedo and the ECU, unfortunately new speedos are expensive and I have a feeling thats not whats causing the problem since it does work some of the time.
Old Mar 24, 2005 | 05:10 AM
jagz_accord
its a speedo cluster electrical problem. you have to tear whole thing apart. its a job for professional electrcian.
Old Mar 26, 2005 | 08:57 PM
2000Ex's Avatar
Well you might be able to get outta tickets for a lil bit.
Old Mar 26, 2005 | 10:01 PM
remington870_20ga's Avatar
Sounds like an ECU problem to me, guage clusters are all mechanical and told what to do by the ECU.
Old Apr 4, 2005 | 12:31 AM
bratva5
I have exactly the same problem. Sometimes it would work just fine but mos of the time it stays around 20MPH. Does anyone ever fixed this and knows for shure what's wrong? Thanks
Old Oct 7, 2007 | 12:37 PM
mickid86
My speedo on my 96 Accord is doing the same thing. And I just got a 75.00 ticket for it not working! Anybody come up with a solution?
Old Oct 7, 2007 | 03:35 PM
If your cruise control works when the speedometer fails, then the speedometer has an electrical fault.
You can remove the gauge cluster and take it apart. You can ship the speedometer to a speedometer repair shop to have it fixed. That way the mileage on your odometer is accurate. I think that I spent ~$120 to have mine repaired.
