skyguy19xx |
10-30-2014 07:32 PM |
squeaking noise help!!
So new person to this forum. I have a 1994 Honda accord ex 2.2L vtec. It just broke 313,000 miles and the suspension is finally going out. My passenger side squeaked first. Apparently I didnt get to it on time and my ball joint and cv axle broke. I fixed that. Now the driver side squeaks. Btw I believe that the ball joint is the cause. So all in all I just replaced on both front sides, the lower ball joints, cv axles, upper joints and arms, struts, outer tie rod ends, and sway bar links. I was going to do the inner tie rod ends this weekend with an alignment, but after I changed everything the squeaking came back after a day. I took the joints off and greased them. Put them back on and still squeaking only from driver side. So now I'm clueless on what it could be. Any help??
